richo 4
Hi all,
as Fibaro is a bit slow with that I have created a function getRoomName(ID) that you can use in LUA.
Unfortunatelly you need to create some additional components to use it:
1. Global variable "room"
2. Virtual device with the following code:
If you want to get the list of your devices with proper ID's, types, names and rooms you can use the following code:
I hope it's not that complicated to use. Maybe someone can simplify it before Fibaro delivers proper "fibaro:getRoomName(ID)"
/emoticons/default_icon_wink.gif" alt=";-)" />1 answer to this question
