Lua method PUT
Shad
Does someone know how to send command with that.
I try many thing like that
But don't work.
5 answers to this question
here you got example with response how should PUT looks (don't need login; password to control HUE?
  • Philips Hue just need to create a user in the api.
    So here what I did and don't work
    if I do that is working
    [ Added: 2013-06-13, 11:21 ]
    Nobody to help me ???
    Guest jrkalf
    not sure, but have you tried to put the payload between quotes?
    Perhaps verify this by printing the contents of the variable by doing a fibaro:debug(payload) to see the output of this variable. Not sure if it works, but give it a go.
    I'm making the assumption that the lua code is not handling the payload variable properly.
    you don't need Authentication?
    Shad, your payload may not look good after encoding
    try that
  • I do my own script in php, so now is working with HC2.
