I have an Everspring flood sensor. I added it to the home center and it looks to be alright.
But whenever I put the sensor tip in water nothing happens....
Do I have to set some parameters?
Hope someone can help me because a water sensor that doens't detect water is quite useless
stevenvd, press that long cable in water and wait you should hear sound (from device) and in hc2 new image
    Nothing happens when I put it in water... no sound no light no change in the HC.
    stevenvd, check battery if that will not help contact with seller of that device, it can be damged
    The batteries are new, even changed them but doesn't help. Probably broken then... bit strange as it is brand new!
