unusable for me... the network is very unstable... connection with the iPhone app very, very slow... sorting scenes does not work, the box hangs = reboot... etc...
new recovery and back to 3.548
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
*bug
When you remove a device (in the device itself) from the alarm. The Icon of that device is reset.
yes i can confirm that
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20"> you can select other devices for the video gate...Ipad/Android will not display the page..
When FGS is selected iphone will work Android not
in android/ipad browser? because in native app is working and that same in normal browser
I cannot remove Universal sensors from the alarm. When I arm the alarm these are also armed. Which is not so usefull as if my doorbell or alarm-clock goes of. the alarm will go of
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
create new room and assign there that UBS, other rooms set arm by rooms page (alarm icon) then will work till we don't find solution
strange 3.550 was many time online and we don't have any problems with sorting or that hc2 is unstable
I'm using the native app on both devices.
Both will not switch to the video gate
With FGS only the iphone will switch
Any way to arm / disarm from the other alarm panel? so through a device. and through the API? I understand it is now finished yet. Just interested on whether it is there of if it is still coming? I think you are doing a nice job! it's definitely a surprise
same problem for me with 3.550... that's why I came back on 3.548... after rollback, no problem with 3.548, very stable and quickly the last 10 days...
ikillou, can you give us a remote access to check what is a reason that for you 3.550+ is unstable?
yes, once the restore is finished, but I'm now back on version 3.548
ikillou, ok when you gonna have more time to try 3.552 again give as a info with remote access. Then we gonna check it
Well, I'm back to version 3.552. I send you information for remote connection with a PM.
Socha is there a way to arm / disarm from the other alarm panel? so through a device. and through the API? I understand it is now finished yet. So just interrested!
stevenvd, by rooms you can right now too
