How to use API to have device ID status?
Arbu-jl
I can use API to send command to HC2 from Irule (e.g. [iPduHomeCenter]/api/callAction?deviceID=12&name=turnOn....
So, now I want to have (to see) the status of my device, with the same philosophy. How can I get the status? Something like that... [iPduHomeCenter]/api/getstatus?deviceID=12, don't know, I'm cannot find something on Fibaro docs... What will be the result? I want to use the result with iRule feedback component.
Thanks for your help...
8 answers to this question
  • Thanks for your quick answer.
    Ok. I have already test that, but how can I have only the Status?
    Are you sure you read this post???
    Get json status from api:
    http:///api/rooms
    http:///api/scenes
    http:///api/devices
    http:///api/devices?id=316 # Specific value of a device
    http:///api/virtualDevices
    http:///api/globalVariables
    http:///api/weather
    http:///api/sections
    http:///api/users
    http:///api/energy/now-3600/now/single/devices/power/58
    return:
  • Yes sure, but to be honest I don't know how to retrieve only the value "status"
    Can I ask you to give me an example?
    Sorry I'm not really an expert
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    If I understand, you only want get the value (on or off, % for dimmer...)
    If it is that, I don't you have a command for that.
  • Yes exactly!!!
    We don't have any possibility?
    Grrrrr...
    Arbu-jl,
    first
    you read last and later use
    Andrew,
    He want only now if the light is on or off, or if the blind is open or close.
    And you pt too much "="
