Hi all,
it's possible configure hc2 witch wall plug or similar to switch off with priority schedule some device when global eletric charge is > to 3,2 KW?
with lua i can monitoring with aperometric clamp global absorption and execute switch off action but....
how can i set device priority ?
ca i set random priority?
es:
global consumption 3,4kw
wall plug 1= 1,4kw
wall plug 2= 1,5,kw
wal plug 3= 0,6 Kw
the priority is plug 2(hight charge), plug 1(med charge) , plug 3 (lower charge)
and the sistem must switch off plug 2...
it's possible?
sorry for my bad english...
/emoticons/default_icon_redface.gif" alt=":oops:" />
8 answers to this question
Swordpirat, in LUA yes
    Ok, i need use bubblesort algoritm?
    you can do that in loop and always turn off device with max W
    example on fast from memory
    why in a loop?
    i call scene only if amperometric clamps dedect > 3,2 Kw...
    if i take this scene active in a loop everytime the
    device with max Kw switch off...
    let say you got that situation
    wallplug 1 1.8kw
    wallplug 2 1.8kw
    wallplug 3 1.7kw
    then you will first turn off 1.8kw but 1.8kw +1.7 is still more then 3.2kw
    your lua scene will start again when you will get new value sensor for amperometric clamps, but if you do that in loop you will get that effect fast
    wallplug 1 1.8kw
    wallplug 2 1.8kw
    wallplug 3 1.7kw
    ok!
    like this...
    while (amperometric clamps value) > 3.2 do
    local wallplug1 = fibaro:getValue(1655, "valueSensor")
    local wallplug2 = fibaro:getValue(1655, "valueSensor")
    local wallplug3 = fibaro:getValue(1655, "valueSensor")
    local max = (math.max(wallplug1,wallplug2,wallplug3));
    fibaro:debug (max);
    if (wallplug1 == max)
    then
    --turnoff wallplug1
    elseif(wallplug2 == max)
    then
    --turnoff wallplug2
    else
    --turnoff wallplug3
    use 3200 not 3.2
    --turnoff wallplug2 use command to turnoff device and on begin add %%autostart
    wallplug 1 1.8kw
    wallplug 2 1.8kw
    wallplug 3 1.7kw
    ok!
    like this...
    fibaro:debug (max);
    then
    --turnoff wallplug1
    then
    --turnoff wallplug2
    else
    --turnoff wallplug3
    I try but...i can view only debug message in console...it seems script interrupt before "if (wallplug1 == max) ....."
    some ideas?
