Hi everyone!
I'm trying to associate fibaro fgr 221 to my Vera Lite unit without success...
Any help please?
Better to go on vera lite forum.
They are going to tell the way to do that. It is just a device, so for work vera lite must have the template.
    Because when my main power board goes down, my buttons of the roller shutter switch dosen't work
    I have to "open" my wall mount, take everything from there and click 3 times on the B button with a paper clip.
    It's true that we have to do it this every time that misses electricity on our house?!?!?!?!
    Cause at the moment I'm just testing one, but if this keep on, I will not take that risk to install FGR 221 on my ruller shutter
    p lopes, no, you need do that only 1, and device gonna remember home ID (controller) till you don't remove it or reset it
    p lopes,
    You must check in your vera how to wake up device.
    Shad, Fibaro FGR 221 that is Roller Shutter so that is not a battery device
    Andrew,
    He say that happen when power go off, so the vera lost the signal I think.
    Example given:
    -I have Fibaro FGR 221 on my ruller shutters. I have 2 rules on my Vera Lite, open at 7am and close 8pm.
    When I want to move ruller shutters on the pulse-buttons of the wall mount it's ok.
    However, If electricity goes off at for example 5pm and I want to shut down the blinders after the electricity goes off on the pulse-buttons of the wall, they don't work :
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />((
    This is nothing to do with Vera lite...
    I had to open the wall mount to click 3 times with a paper clip on the B button.
    I can't believe that we need to do this procedure every time that electricity goes off
    p lopes, 3 times click is only to add/remove device from system that is impossible!!!, you don't need that to set up associate
    i don't understand that part
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">((
    how you want controlling device when he don't have power?
    but when power will back it will work
    With the hc2 i don't have problem when the power go off. It is for that is better to check on the vera 's forum what you must to do.
    Of course, when I said the electricity goes of... and come again few seconds after.
    What I want to said it was,
    Once that the fibaro fgr 221 it's inside of the wall mount and I want to up and down my buttons of the roller shutter blind manually that's work fine when don't miss electricity even for seconds.
    BUT
    If the electricity goes down and come again (of course), the buttons of the roller shutter don't work anymore, unless I click 3 times on the B button of the fgr 221
    And this don't have nothing to do with VERA LITE.
    p lopes, please contact with [email protected] tell them about your problem, that can be damaged module because normal module don't have that problem
