Anyone else noticed that the window sensor type in scenes will not allow you to set it as a trigger yet if you swap it to type door sensor it is working fine!
Not only if you save a scene with this sensor as a window but the scene not working correctly with this type sensor. It was reported on the bug tracker (733 and 741)
