FGS-211 - on / off inverted radiator with pilot wire (France
Fibaro on FGS-211 modulates the function On / Off is reversed.
This turns on the heating as it is Off and off when he is on.
Could you put an option to reverse it on the HC2 interface?
In France all the radiators work on pilot wire.
In the heating panel can not do programming because it turns the heater off when it should.
Thank you in advance for your return.
[ Added: 2013-10-22, 16:33 ]
Still no solution, the team has no effective air though the problem would soon be solved if someone decided to reverse the on / off button.
Basically I have a box HC2 which manages heating but does not manage it, then either this function is implemented once and for all, or I post on all the automation that HC2 is not compatible with the pilot wire forum in France and it is therefore useless to the çi to do that. I think I described the problem with assertions details. For full-time friends are interested in purchasing I kindly told them to expect this feature to be functional for France or THERE A PILOT WIRE.
So if someone could move Fibaro and we lay a reversal of the on / off button that would be cool.
Thank you to consider this request, which is several months.
  • 7 months later...
I have the same issue.
It should be "easy" to implement this reverse function in the HC2...
TIA
[ Added: 2014-04-27, 18:41 ]
up
