Call button virtual device in scene
How to execute a button of a virtual device?
I think it's easy but i have not find this information.
a button of a virtual device have not ID?
Hi, if you are using graphic mode, after a Then, just select Virtual Devices -> and choose the virtual device you want. In LUA it's even easier, just move your mouse over the virtual device you want to activate and it will give you the required code (i.e. fibaro:call(66, "pressButton") )
Hope it helps
Riccardo
    can you give me a screenshot please
    [ Added: 2013-07-02, 18:59 ]
    It's ok.
    %% properties
    6 value
    6 armed
    %% globals
    if (
    ( (tonumber(fibaro:getValue(6, "value")) > 0 and tonumber(fibaro:getValue(6, "armed")) > 0) )
    or
    then
    fibaro:call(14, "pressButton", "1");
    Loof on left menu when you go in lua code. Everything is there.
