Turn on all wall plugs by auto approx 30 min before sundown
Is it possible to make a lua which turns on all Fibaro Wall Plugs approx 30 minutes before sundown......and off again at a certain set time like 2330 or so?
7 answers to this question
Yes, can be done. Here is an example how to turn on 1 device 30 minutes before sunset.
    Super!
    I looks like it turns on both 5 and id 66 is that right?
    Btw do I put this in HC2 as a virtual device or as an scene?
    Does it get called at startup of HC2 due to beeing %autostart% ?
    Super!
    Yes, in my test scene it turns on both id 5 and 66.
    The %%autostart value is that scene starts when HC2 starts up but do not activate the scene until wanted time has been reached.
    Guest GG
    And if you want to make your scene a little bit easier to read, you can write it like this
    Converting scenes from block to Lua creates a lot of unnecessary code.
    Regards
    Yeah I noticed. Damned. Then also the blocks need a better if then else kind of syntax....
    So why would I like this? It seems only to be used for pressing the button manualy and turning lamps on....would never do that. Or does it have any other uses?
    elseif (sourceTrigger["type"] == "other") then
    fibaro:call(5, "turnOn");
    fibaro:call(66, "turnOn");
    Guest GG
    I don't think so. I never have that part in my scenes.
    I can understand the code but why check "other" ?
