I have two of Fibaro door/window sensor. One of them send a lot of alarms, while the other one only send when door is opened. The one that send alot of alarms seems to send alarms even when none touched the door. Could the module be faulty?
The two parts of the sensor is fitted perfectly within 2mm of each other when door is closed. So could it be something else? Settings in HC2? Z-wave range? (it has never shown up as dead node)
Maybe I thought it could be the back button on the sensor that is pressed due to tight fitting to the doorframe with the supplied doublesticker?
[ Added: 2013-07-04, 02:46 ]
I removed it from the door and put it on a table. While just lying there it was jumping on/off without anyone touching it. I have another one that doesnt do this. Can I adjust this or is it broken?
