Hi all,
The default value of parameter 10 is 1. When I change it to 0 the smooth dimming and smooth on/off is disabled.
Does the value 0 increase the reliability of the device and LED bulb? Or is this nonsense.
Jasper
  • 5 months later...
P10=0 defenitely increase the reliability of FGD-211.
There are dimmers that has problems when S2 is associated to another device. Sometimes when you press S2, you need to press S1 3 times then to switch on S1 (
I personally have 1 dimmer that has this problem very seldom, and another one where it occurs almost 100%.
So I fixed my dimmers with setting P10=0. But is looks isn't as good as with smooth dimming.
/emoticons/default_icon_sad.gif" alt=":-(" /> Another alternative is lua workaround for S2 (see the link above)
