I would like to install the FGD211 behind a wall outlet. Can someone direct me on how to wire the module with the outlet given that is 3 wire setup ( N, L and ground).
Rg
Marck
Hi Marck,
What is the problem with wire diagram in Fibaro description.
check Fig2
There is no need for the ground (green yellow)
N= Bleu
L=brown
O=black
    I would like to use the module behind a wall outlet (wandcontactdoos) and not a switch as explained in the manual. Given not I'm electrician, I just want to make sure how to connect it. And given that there is no switch in between, there is also no black wire.
    I don't want to have those blue sparks again from yesterday evening
    Rg
    Marck
    Marck,
    Connection is the same
    se the quick draw
    Dear Tane,
    Thanks for the drawing. I connected the dimmer as suggested. If have a lamp connected with the wall outlet. The setup works partially, since I can't switch or dimm the lamp.
    On the software side everything seems to be fine, via the Razberry I have included the device successfully.
    Anything that I could do to make it work?
    Kind regards,
    Marck
    Marck,
    There are two possible problems.
    Module is defect (the bleu sparks)
    Light bulb can't be dimmed
