MSB 0
GlobalVars [scene] and [Device]
I created a script that runs every minute and does check for certain events in the home like tv running to avoid turn off lights even if its after midnight which normaly means lights off. This to avoid sitting in the dark just because you are up a little later than normal. It can also be used to arm/disarm when everyone left house andso on. It consists of two things 1 device and 1 scene. It will always return 0 or 1 for events and it keeps all dates to unix timestamp for easines when programming. Events are also automaticaly delayed like for instance if you turn off the projector and then decide to to turn on the tv like 5 minutes later it will not turn off the lights since it will tell projector is still running for XX minutes after turn off, after that it will see the tv is on and fend of light off until you turn the tv off to. Anyways I made it so as to keep it simple with 0 or 1 so it is easy to create scenes based on the variables. It has a few more vars like sunriseafter and before sunset. Maybe it should have before beforesunrise to?
To check iphones on/off?
Device button 1:
Device button 2:
Scene to make global variables:
[/code]
4 answers to this question
