Scenes with GPS not working
I have a question about the scenes with the GPS. In my home center is not showing the tab family, which would allow the tracking of users, without it seems my HC2 is not seeing users then could not set up the scenes with GPS.
Any solution for my problem?
alutke, it's work ...
contact with [email protected] and they will tell you what you must to do
I have the same thing, the only support sugestion - report it to the bug tracker
i suggest support not bug-tracker because it's work
but I call them and send e-mail. I recived sugestion put into Bug tracker
change GPS accuracyfor 30m and check then
I wanted to confirm that the GPS works, but is too insensitive, sometimes it works, sometimes in the same condition no longer works.
I have created 2 different scenes to test it, it works in a scene from time to time, while the other has never worked
Sorry for my english
Hockey, that is gps fault. Phone who have good gps can do scene "show in point" other must use show in area
Socha, tracking works fine, only the scenes are occasional.
I have a Samsung S II with Android 4.1.2.
Hockey, show at point must be almost exactly in that point that way is hard. you standing in point but you get point 10m away from that place that way i suggest use show in area
And please call me Andrew or A.Socha
Sorry A.Socha
I put on the phone location accuracy 10m
Thanks and sorry
not work on iPhone 5 with IOS 8, I tested.
The app Fibaro for iPhone not have permission to use GPS. i´m sure for this.
on iOS and iPhone - Fibaro app is clearing privacy location setting (from Always to none) - each time is started. it is not working as advertised (it should be marked as feature Android only)
It used to work with iPhone almost a year ago...
It does not work now. iPhone 6 latest iOS. Fibaro App does not keep that location services are allowed.
Guest vipernor
I don't get it. This is THE thing that needs to get sorted out ASAP. The phones are one of those things that actually can distinguish between home and away, which normally is implemented in a lot of  scenes due to the variables. Is there anyone out there that could make a decent iLocator plugin which is connected to iCloud -> iPhone/iPad/Mac etc?
I used a work around. I created a variable "away" entered it as condition in a scene and I run it when I leave the house. It sets the alarm, turns off devices etc. When I get home I run another scene that deactivates the alarm. And my iPhone's battery is not drained out by the HC2.
Guest vipernor
I use the same scene as well, but I don't want to always have to run this scene manually. The scenes should be run by the different persons phone. Ex. If Bob's phone is "Home", Anna's phone is "Away", John's phone is "Away"....run scene Party Bob. I shouldn't need to even think about which state/ scene is running.
, i used to have it like that but since te iphone app disables the localisation service when it's started I gave up waiting for an update to the iPhone app.
The location/gps does not work on my iPhone 5s.
I have firmware 4.048.
What should I do?
Did you check if localisation permission has not got unchecked?
