Lockzi 1
I have installed a dummy wallswitch (with 2x1,5kw Fibaro Relay - S1 named "Bed transmitter Wind") that is connected through associations to another Fibaro Universal Dimmer that controls LED-lights.
The problem I am having is that the two devices are not updating each others status, which gives me the result that if I use the app to turn OFF the lights (on the actual device that controls the load to the LED-lights), the dummy wallswitch will still state ON. Pressing the button one more time will just change the status of the dummy switch to state OFF, and another push is required to get it to change BOTH devices to ON. This only happens when the status of the real device (that controls the load) has been changed through the webinterface/app.
Is there a way to easily solve this?
Dummy switch configuration
Real device's configuration
