Hi!
I've been trying to connect my electronic lock to a universal sensor, but it still fails to perform the opening through z-wave network. Does anyone have a tip or wiring diagram that I can use?
I imagine that this is the way to make the opening and closing of doors by z-wave network, if I'm wrong please correct me.
Thanks in advance.
universal sensor is just a sensor, you cant' open a door with that.
    And is there any way to do it? Or just buying the ready in standard Z-Wave?
    Use Relay switch and configure the advance settings in such way to keep the lock opened(Normally closed type) for some designated time when the relay is activated.
    *I belive currently No Zwave locks are supported by HC2, not sure
    The one I want to buy is magnetic lock. Only one problem, no power, the house is open.
    Guest Kuuno
    i have the same system but it is closed when no power, open only when apply power:)
    Kuuno
    • 8 months later...
    Kuuno
    Kuuno,
    Could you give us the brand of this device.
    I would like to go for a magnetic lock but indeed when no power house is open.
    So i'm quite interested in your system. Brand or website to buy or link would be very helpful...
    Thanks a lot
    I have this one:
    You have to apply a voltage to open the door, so no voltage, door closed.
