I know I'm asking several questions here, some (most) halfway stupid, but as I said before, I am now starting to automate, so I end up with several questions, always wanting to do everything as accurately as possible.
The question right now is: what to do when my door / window sensor with LED is access? Not to lie it comes off, for less than a second, every 5 ~ 8 seconds. Dont Blink. I can not remove or add for my HC2, tried the reset procedure that is described in the manual but without success.
I was trying to add a sensor DS18B20, that's when I came across this error. Has anyone experienced this? Any way to solve?
Thank you.
[ Added: 2013-07-15, 21:11 ]
Resolved, took and put the battery, and tried for about 3 times to remove the device, there could finally remove it to add it.
But the problem that made ​​me get in there is that I can not arm the device, whenever I try to set the error occurs "Arm action failed, the devices que not meet the conditions."
Obviously I have done something wrong, or am not doing.
  • 5 months later...
I'm just starting with domotics.
I have exactly the same problem with one of my 3 doorsensors.
Isn't there a list with errors and the probable causes and solutions?
Thanks!
Update on 10/01/2014:
After putting HC2 more centrally in my house, problems were solved.
  • 1 month later...
Thank you.
I have the same problem. If the sensor has tripped, even though it is not armed you are not allowed to arm the device. In the settings for the device you can change the conditions for arming a device. The two choices i have is "safe" and "breached".
If i set it to breached i am able to arm the device if it is in breached mode. But then i am not able to arm the device when it is safe/not breached?
Any body who knows how this can be avoided?
Edit:
So i found out how to do this. You have to press the add/remove device under the Device arming conditions. Open it up and uncheck the selected device. You are now allowed to arm and disarm the unit.
