Hi have been trying for some time to configure a dimmer with a couple of stair switches.
I have followed this wiring I've found in the forum:
/files/thumbs/t_fibaro_wisselschakeling_199.jpg" alt="t_fibaro_wisselschakeling_199.jpg" />
I am able to turn the lights on and off from HC2, but the phisical switches do not turn on or off...
...unless I press them twice (!?!?!?)
I've tried to fiddle with the configuration of the parameters, but it comes between this and completly dead...
Help?
Thank you
sounds like the parameters are not set for the type of switch
It does sound like parameter 14 is not correctly configured.
As a default it is set to 0 for momentary switches - but it sounds like you're using toggle switches.
If this is the case, change 14 to 1.
There is more information about using different switches in this guide -
And also common wiring for 2-way lighting (stairs lighting) -
