Turning off with Time lua code
I want to turnOn and after 10 minutes turnOff the lights. How can I add the run 10 minutes than stop part in lua code? here is my code but it has not 10 minutes part. it is only on/off part.
local current_isik = fibaro:getGlobalValue("isikdurum");
b = tonumber(current_isik);
if(b==0)then
fibaro:call(9, "turnOn")
fibaro:setGlobal("isikdurum",1)
else
fibaro:call(9,"turnOff");
fibaro:setGlobal("isikdurum",0);
Thanks a lot.
5 answers to this question
Not sure If I understand what do you want, but try that.
    Actually I want to turn on the ligths. After 10 minutes they are closed automatically. I asked that how can I do it with lua code?
    Thanks.
    Ok so normally is working.
    hco,
    hco,
    thank you for your help.
