I'm adding a relay module, needed to remove and add it in the same HC2, but adding it does not appear in the devices tab or anywhere. I tried the delete procedure and adding a few times, and holding the B button for 3 seconds or more, and nothing done. By adding, when it still does not seem to be added appearing on the flap devices. Any tips?
[ Added: 2013-07-23, 16:34 ]
Problem solved.
To remove device, just clic on interface of HC2 delete device then push three time button on device.
