v .354
Guest shapa
Guest shapa
It's a kind of magic, multisensor and z-wave bugs are accepted and fixed (?)
3.554:
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes.
Bugtracker tickets:
- 0000784: in german translation no values in devices configuration
- 0000778: Missing translation
- 0000769: Error message in dasboard
- 0000772: błędna data zdarzeń w panelu Alarmu Fibaro
- 0000779: Fibaro Alarm panel
But:
Update in progress
Upgrade Error: 5
Question: ????
same for me
Guest dsilletti
    same for me
    This update is OK for me... I made ​​yesterday at 22:00... installing this version last very long... but it worked...
    Same here - update error 5
    Guest AxelS
    and here ... Update Error 5
    Guest deraaij
    yup also Update error 5....
    Since I try the update yesterday, the HC2 freeze. Somebody have that problem ??
    Shad, freeze? after error 5 hc2 is restarting and you should saw interface again
    We checking problem with error 5
    Hello
    Also for me error 5. I'm updating from Beta 3.553.
    When I got the error HC2 freeze. I need to restart for normal use.
    3.554 is a Beta or a stable release?
    3.554 is a new beta
    if you gonna wait after ok you will saw 503 and later HC server will run and you will saw interface w/o restart
    upgrade is stopping after few min.
    Guest shapa
    Still not fixed...
    Yes, interface don't response.
    I am going to do a hard reboot and see what happen.
    3.554:
    - Z-Wave bug fixes.
    Bugtracker tickets:
    But:
    Update in progress
    Upgrade Error: 5
    Question: ????
    After trying to update i have the 503 error ... and i can do nothing to resolve it ...
    Can you please help me ?
    Kind regards
    Pascal
    Guest shapa
    It could be related to DNS issues - tonight I realised that you've got some issues with DNS (for example forum address was not available to resolve) and it is not possible to open the website.
    Which URL / DNS name is normally used to receive an update? There are some chances that virtual server is not configured correctly (BTW, it is not really serious to use virtual names resolution but share IP with another web site, like
    - v66.c3.dhosting.pl) - it is normally accepted for a very small company or private use
    Restart HC2
    Guest shapa
    Shad,
    restart not helps at all for me - still not possible to install the update
    The problems for me is not the update, is if I want close light and I refresh pagen the light is still on.
    Like RGB device, this one stay on but led is off
    /emoticons/default_icon_rolleyes.gif" alt=":roll:" />.
    So when return home, reboot everything. And hope
    problem with update is fixed. Sorry for problems
    Guest deraaij
    worked, thnx
