Rgbw and lua
trackingnewtech
Hi in lua the only thing i do is to change the value ON/OFF.
But is it possible to change the color or to lauch a program of colors
/emoticons/default_icon_question.gif" alt=":?:" />
Is there somewhere any lua reference about this module ?
Best regards
Very strange issue, so I have two question for fibaro because I really don't understand:
If I do that
The led turn on.
But if I do that:
The led stay off.
Can you confirm.
Other problem, when you call back the last color with
your return a value like 50,50,50,0. So to put " you must do
So not very easy.
After maybe I make a mistake but if somebody can confirm if you can or not turn on led stip with a local at the place of normal value.
Domodial, Shad, you can try this:
the same as method:
Shad, i think fibaro:getValue(354, "lastColorSet") would have had to return a "table" in the place of a "string"
/emoticons/default_icon_idea.gif" alt=":idea:" /> , if Fibaro can confirm...
@Krikroff
Debug return if I turn green ON (163) :
[DEBUG] 11:54:19: R:0
[DEBUG] 11:54:19: G:163
[DEBUG] 11:54:19: B:0
[DEBUG] 11:54:19: W:0
Strange that way work and not my. It is the same value.
Nevermind, if that is ok.
Shad, you do not do the same thing
For
i think the arguments are fixed and you try to put a string that represent the arguments R, G, B, W.
but I may be mistaken
This is my code
Is that okay? What is your question...
non, du coup je ne sais plus ou mettre mon programme pour voir si la couleur initial repasse ou pas... je deviens fou
try:
Wouaaah! Thank you very much it works the first time!
You write LUA as the river flowing! Again thank you 1000 times!
[ Added: 2013-11-16, 16:23 ]
There was one last detail, if the color is fixed, the scene starts and after time, the color returns. By cons, if it is a scene that is launched and not a fixed color, the module switches to OFF and do not come back to the previous scene.
[ Added: 2013-11-18, 09:42 ]
@KriKoff
Have you un best code line idea for working on program ?
Regards
Domodial
[ Added: 2013-11-19, 10:54 ]
up
I want to set the dim level of an RGB module. If I run this code then the colour never changes, instead the rgb module just dims to 60%
fibaro:call(245, "setColor", "255", "255", "0", "0");
fibaro:call(245, "setValue", "55");
But if I put a 1 second wait in the code it works perfectly:
fibaro:sleep(1*1000);
Any ideas as to why this is happening?
