How to remove unused Universal Sensor inputs?
Guest dsilletti
Hi, all my Fibaro Universal Sensors are used only with 1 motion sensor, how can I remove the second input from the dashboard and from the Alarm Panel?
I already put the unused input in the Unknow (Not Assigned) Room, but this is not the solution...
How to hide the UBS itself from the Alarm panel? (I should arm only the desired input, not the UBS)
Thanks in advance
Domenico
dsilletti,
No, you can not hide one of UBS inputs.
You can move it into another room and then you can hide room by set up access in user panel.
Guest dsilletti
    dsilletti,
    Thank you for quick answer, what about to include the possibility to hide unused UBS inputs in the next releases? (like for 2x1,5 kW ON/OFF switch, where we can hide child device)
    regards
    Domenico
    we will think about that, now if you don't use that one endpoint and all time is not safe you can by parameter change value to opposed to have all time on that one endpoint safe
