I want connect my sprinkler with HC2 but I have a question.
How can I cancel for all day if is rain???
I want to know if I must use this kind of
or it have a special function for that.
5 answers to this question
you can made LUA scene who going do that (like to control heating panel is almost that same)
    Thanks I will check. Don't use heating panel in africa, but waiting ZXT-120
    i was wrote a script who doing that if you find it then you need only modify few lines like ip, url, value to send
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    Hi
    Have a look a this thread
    Hope it helps
    R
    Shad, Checked ZXT120 with Vera, It doesn't seem to be perfect device to control AC with IR control. SET point will not control the compressor, It will only Turn ON/OFF the whole unit. Instead if Virtual devices are included in Fibaro HC2 app, I prefer to use Global Cache IR gateways.
