Yesterday i broke antena of fibaro d/w sensor. Naturally no antena = no connection!
Reason ; im trying to connect door bell to d/w sensor. Maybe 10 times i tried different connections but no result.
I also asked fibaro support but they talk only about diagrams. Im not a electrican. Can anybody tell me how do you make a d/w connection to door bell (attachmetn my current connection) ?
(I opened case and used a soldering iron-you say lutownica and cleared solder then embed antena in the hole again, now it works...)
Just to be sure, you are not using this sensor to ring the bell.
Because this a sensor for input. You can't use this one to do output action.
    Can you explain this connection sent to me by fibaro support?
    I want to get a notification when somebody press door bell.
    First, to be sure you sensor work, connect wire together and check if you receive notification.
    If you have nothing, check parameters and be sure you connect your doorbell before you add sensor to HC2.
    Then if is ok and I understand everything well, connect COM to A1 and NO to A2.
    What is COM A1 k1 NO etc.. i dont understand
    Can you make an example with wires? Is it like this?
    You have two possibilty.
    1- You connect on each wire of the button.
    2- You connect on each wire of the bell.
    For each you have two wire and same on the sensor.
    Did tou try to connect wire to see if sensor work???
    Look at my first post attachment. My battery become useless after 24 hours in this connection. (i didnt take it off from door bell)
    If i connect wires to sensor yes it blinks.
    So my previous post's attachment is true?
