Poll device from LUA?
Guest shapa
I need to poll some device (Vitrum switch) from LUA as it's not reporting status changed to controller in case his status changed via associated control panel.
Polling should help (I need to poll the device only in case some scene started, i.e. it is not a good idea to decrease polling periods for this device)
6 answers to this question
shapa, do that device got associations group?
if not then only by manual pooling you can do that try with 900s (1 ask on 15min) if you need smaller value try don't go lower then 300s
Guest shapa
    A.Socha,
    This device is detected as a "generic" one (screenshot is attached)
    Yes, there is only one association group, but in fact is is very nice 4 button wall panel
    The issue is that I need to know from a scene that light is switched on manually (from scene controller or dimmer itself) and to disable "high light level" threshold (i.e. do not switch lights in an auto-activated scene).
    Suggestion to use 300sec is not an option as I need to know that light is switched on faster (when a scene triggered with high light level)
    shapa, remote control, i can't help. sorry. Device what you controlling should send raport to hc2, if not doing that use our module
    Guest shapa
    "should send raport to hc2" - this device (vitrum dimmer) sends report without problem (when I'm changing anything on the device directly), report is not sent when _remote control_ changing device status.
    With Vera3 I could easily poll device from Lua when it is necessary. What is the reason not to include this functionality to HC2?
    Device I'm talking about:
    shapa, if you sending by remote control action turn or turn off device should report it, if you dont have that information then change module for that who gonna report
    Guest shapa
    It is not reporting, which is very confusing. What does it mean "change module"? Change vitrum switches? Each one is 300$+.
    BTW, it could be HC2 issue - dimmer status is not detected correctly after polling period also (but detected in case of forced reconfiguration ("configure to default settings")).
    Is it possible to arrange some session to check where the issue is?
