pls90 0
I am trying to use the RGB as a sensor for analog devices.
I have a lightlevel sensor and a wind sensor which provide a output voltage 0-10V acourding to light level or wind speed.
I found this document how to setup the RGBW with non Fibaro controller.
My settings:
14 to 34952
43 to 1
Vera light shows the RGBW as a dimmer with dim level acourding to input voltage.
If I set 12V from power supply to input 1 the "dimmer" device in vera shows 100%.
If I short input 1 with GND it shows 2%.
So far so good, input voltage seems to be reported.
With no sensor attached the "dimmer" device in vera shows 100%.
I measured the voltage between GND and Input1 without sensor, it is 10V.
When I attach the sensors the voltage between GND and Input goes to 5V, although the sensor output voltage is 0V (no light or wind speed 0).
I never get voltages below 5V or above 7V.
The sensors work correctly, when not attached to the RGBW their output voltages vary with light level/wind speed between 0-10V.
Any ideas as to how configure the RGBW would be highly appreciated.
Peter
