Watering panel is not working
Guest dsilletti
Watering panel is not working, I choose a fibaro wall plug to control the electro valve, then I setup 2 cycles at 7 and at 23 for 15 min every day, but at 23 the wall plug is still off...
Regards
Domenico
6 answers to this question
dsilletti, you was chose "auto"
Guest dsilletti
    thank you, I didn't, now it's working!
    Regards
    Domenico
    [ Added: 2013-08-12, 00:53 ]
    15 min is the maximum time? I need 20-30 mins
    regards
    Domenico
    Adjust water for sunshine by 60-100%
    Hi what does Adjust Water actually do? Extend watering time? And does it only apply to next cycle?
    Would be nice to set watering to between 30-60 miutes with 10 min steps
    OK i think i know the answer to both (but feel free to correct me)
    1. Adjust Water in sprinkler panel extends the watering time by a given percent
    2. No - it apply to all cycles, not only the next one.
    Here is what i did. I added 2 buttons to my watering VD - Susza (d
    ) On and Susza Off. One Adjusts Water by 60%, second one resets back to 0%.
    Example for ON:
    Then you need 2 scenes: If humidity is < 45% and temp > 30 degrees - Press the On button. You will need one more to press the off buton, or just use LUA
    UPDATE: As I am not LUA expert, all comments appreciated:
    633 is my Aeon Labs 4in1 Temperature reading
    186 is my Netatmo humidity
