Start scene when SATEL Integra armed / disarmed ?
Hi A. Socha, could you explain me how I can start a scene when I arm / disarm my satel alarm (from keypad, satel iOS app or fibaro app)? Because Partition Arm/Disarm is not found in scene panel...
Best regards.
5 answers to this question
Krikroff, Assign an output to "Full Armed Status" in the DloadX configuration (Outputs data)
This will switch on when armed and off when disarmed and the output will be available as a condition in the scene interface
    Thank you JohnnyC, it sound good! What the best way for you: physical or virtual output? Have you programed special virtual zone or other to implement more interaction between HC2 and your SATEL alarm?
    Thx.
    I am waiting for more detail on the iPad application and iPhone update and how the Satel system will be represented in these. Currently it is a bit confusing or maybe not quite finished
    A lot of scenes in my programming are based or conditioned on alarm status so it is important for this. I just used a physical output.
    I am waiting for more detail on the iPad application and iPhone update and how the Satel system will be represented in these. Currently it is a bit confusing or maybe not quite finished.
    I'am totally agree with you
    Thank you for your help.
    HI
    beloow code of my scen with start scen depend of disarm Satel zone
