Activate a scene with the dimmer s2!
Guest Eduardo
Hello there.
I´m very newbie in Lua, and i´m trying to activate a "good night" scene with the dimmer s2.
I activated the parameter 41 and maded a new scene with the scripts below that i find it in the forum. But my doubt is, what is the next step.
Thanks in advance.
%% properties
35 sceneActivation
%% globals
local id= 35;
local name = fibaro:getName(id)
fibaro:debug(name);
local name = tonumber(fibaro:getValue(id, "sceneActivation"));
if (tonumber(fibaro:getValue(id, "sceneActivation"))==16)
then
fibaro:debug("1 click s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==26)
then
fibaro:debug("1 click s2 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==25)
then
fibaro:debug("3 click s2 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==15)
then
fibaro:debug("3 click s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==14)
then
fibaro:debug("2 click s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==24)
then
fibaro:debug("2 click s2 "..name);
elseif (tonumber(fibaro:getValue(id, "s2"))==24)
then
fibaro:debug("hold click s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==13)
then
fibaro:debug("release click s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==22)
then
fibaro:debug("hold click s2 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==23)
then
fibaro:debug("release click s2 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==10)
then
fibaro:debug("change from turn off to turn on s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==11)
then
fibaro:debug("change from turn on to turn off s1 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==20)
then
fibaro:debug("change from turn off to turn on s2 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==21)
then
fibaro:debug("change from turn on to turn off s2 "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==17)
then
fibaro:debug("up "..name);
elseif (tonumber(fibaro:getValue(id, "sceneActivation"))==18)
then
fibaro:debug("down "..name);
end;
Hi m8
something like this perhaps?
Guest Eduardo
    Hi there Jonny!
    that was very helpfull! I just changed the ID dor the S2 and works perfectly!!!
    Thanks a lot!
    Regards
    Eduardo
    [ Added: 2014-03-31, 10:46 ]
    Can I activate a scene with s2 of a 1.8 dimmer???
