Store and read from variable
Store the value of a device in a variable en set it back again.
When running a RGBW program for alerting the previews settings will be lost.
I'm looking for a method to set this back after the program is finished.
Settings for device 296 W are stored earlier in a global variable.
Running the program en trying to restore the W back…
The script is not doing what i want….
fibaro:call(296, "startProgram", "6")
fibaro:sleep(10*1000);
fibaro:call(296, "turnOff")
fibaro:call(296, "setW", "StatusBuro")
To optimize a bit more
Store all the settings of the device in a variable
run the program.
set them back...
8 answers to this question
TANE, sorry but your code got 2 bugs and is totally not understood for me
    Andrew,
    Before staring the Program 6 I need to store the Color W status.
    This can be any value from 0-255
    After the program is finished set the value back.
    Almost there..
    White is doing nothing at the end..
    looks like the sore white is not working...
    this will display 99
    Main ID is 296
    Meter is 297
    R=298
    G=299
    B=300
    W=301
    mistake in last line (code written from memory)
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    Andrew,
    thanks
    White will always set to 99
    even when it's off or the value is 255
    debug is always displaying 99
    TANE, brithness is from 0-99
    color is fom 0-255
    okay...bit it's always 99 even when it's off
    I can multiplay that wit 2.54..this will set to max.
    [ Added: 2013-08-15, 23:15 ]
    Andrew,
    Status of the device 301 is not updated. no matter what done.
    It will be great to have direct access to child the devices in the interfaces..
    The option show child devices is welcome
    I use the RGBW for white led strips..you can connect 4 of the to one device. I like to have direct access to all of them from scenes.
    What i have done to let it work.
    Set the status of the device in a variable when turned on/off
    From the Lua just use the status to set it back.
