Switch control of RGBW device and RGBW light strip
I've read the PDF guide on the RBGW product page - but I'm still confused on what are the options for switches to control the RGBW device.
I'll code scenes on my Vera Lite in LUA - but how can the device be controlled manually, with wall switches?
- on/off (resuming to previous colour and brightness levels?)
- dimming all channels together? I can imagine a row of 4 on/off/on momentary switches to dial individual RGBW levels separately, but I've not seen reference to on/off/on switches in the PDF.
- dimming individual channels up/down?
Or, is level/dimming only available for control by the RGBW over Z-Wave, with only on/off status of each channel controllable by switches?
So what control actions are available, to what types of switches?
thanks,
Ben
thanks,
Ben
    Does anyone here have experience of controlling the RGBW unit with wall switches?
    Guest mhn
    I have set up a little test and try to understand the potentiometer setup. No luck so far.
    Can someone point me to more information about input control of LEDs?
    There's a link in the manual (for parameter 14 settings), but it's not working.
    Regards
    Morten
    How can i link 3 RGBW controllers that i can control al together at the same time?
    I wil control all the controllers run the same collor
