OREGON SCIENTIFIC & RfxCom RFXtrx433 USB Support
Hi Fibaro
Is the OREGON SCIENTIFIC support planned in the near future ?
ATM it's the best (and only !!!) weather station devices out there.
BTW: Are you planning to support the 433 protocol ( RfxCom RFXtrx433 USB ) ?
This is the only thing holding me buying 2 HC2 devices.
Thanks alot for you replay.
  • Answers 80
  • Created
  • Last Reply
+1 or a plugin system, that i can build some system to communicate with rfxtrx.
That will be a greate plugin.
For know you can use a Vera lite with the rfxcom connected to the Vera.
From Hc2 you can trigger scenes and devices that are connected to Vera via rfxcom
Fibaro I will send you a rfxcom if you are intrested..
Guest mhn
Rfxcom is a important part of my house too.
Guest b95_lun
Guest jrkalf
A plugin system is a good idea..
Oregon scientific isn't the only weather station btw.. I love the abilities of Cresta devices as well. All be it with a usb output.
Just one device for all.
Rfxcom / Cresta will also work fine.
most of the 433.92 devices is supported.
    UP ^
    Any answer from a Fibaro group ???
    Guest shapa
    one of the reasons (+missing locks support) why I'm still using Vera3
    Guest jrkalf
    Hi
    Waiting also for this to dump my Zibase and switch to HC2
    +1 as I am just moving from HomeSeer where I have had this support for years
