Forum Users should know first:)
Will Flood Sensor supported only in next HC2 FW release?
I included it and it came in as a motion sensor. If I change it to flood sensor, parameter list is missing.
On the other hand I can't arm it neighter and no temperature sensor presented...
I had also some troubles running latest beta version and adding flood sensor. I do not have any assosiated group...try to add and remove device many times,nothing happened. I cannot also disarmed my sensor. But I have temp. sensor
wasil, that will be fixed in next beta
Thanks for the info A.Socha.
Till than I will put it back in the box.
Excatly,without assosiated group it is now rather useless
/emoticons/default_icon_sad.gif" alt=":-(" /> And it is shame that support did not know about that when I called them today morning...Few hours lost to make something impossible. Waiting for the new beta then,hope it will come very soon
hasol, wasil, just do restart hc2, after that you will saw associations, that is only bug with refresh
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
I am not sure if I did not do that but will try tomorrow. Do not read second part of my PM send to You then
For me no success with restart...
Try to press button "Make default settings" and then You have to wake up device manually -> open it -> press 3 times tamper and on the command window You will see how Your device is making new settings. If that will not help then ask support.
Thank you wasil , now it seems better than before.
After new restart associations are finally there.
You are welcome hasol
My vision of the best 7-in-1 Univeral sensor:
Already included:
Light
Temp
Humidity
Motion
Extra:
Siren
(maybe doorbel)
IR sender like the Cache. So you can control IR Devices like amplifiers in rooms
Guest Kuuno
    included very well for me
    Can you trigger the temp NC or Alarm NC from the Home Center?
    By a scene or something?
    • 1 month later...
    Thanks. I ordered now two of this sensors.
    Btw., why does the duck have a housing ?
