RGBW Control via iPhone and iPad Apps
I have installed two RGBW controllers which work fine through the web interface.
I'm running the latest Beta software on the HC2.
When I access via the iPhone, the RGBW shows up as 'Unassigned' and not under the assigned room. I cannot set the colour or control it as I would expect, instead I see a number of sliders and it is niot clear what they do.
Teh marketing i nfo suggests that I should be able to set colurs via my iPhone - is this the case or not?
On the iPad the device does not show up at all.
11 answers to this question
iphone will not show de RGBW devices. (hope the next version)
Latest iPad app 1.1 with beta .59 will work fine
    Thnaks for the quick reply - in a way good to know that this is just a pending development and not some odd configuration problem.
    On a related note, I'd like to link the two controllers so they synchronise colours etc - how can this be done - I've associated them in Group 1 - but this seems to have no effect?
    I would to know also, how to retrieve colour in lua code.
    automationfan, you must set association to all 4 groups
    Shad, use list of device from scene to get property color
    I've added association in all four groups for both controllers, or for one controller. This does not seem to have the desired effect - both operate independently?
    parametr is set correct?
    For each group, the parameter is 1,3 except for Group 5 which won't accept this value.
    This is achieved by ticking the box for the other RGB controller in the selection.
    automationfan, association working from buttons, if you want have full associations (INTERFACE +buttons) use lua
    OK thanks - so this would only work with a directly connected switch to the RGBW controller?
    Any hints on what LUA code I'd need to enable this via the web interface too?
    read propery color in lua and later setup that color to second rgb
    any update on this issue?
    I have currently installed roller shutter 2 and RGBW module, both works fine with web interface but not showing at all in iPad or iPhone. Any idea?
