Hi all,
i need for a counting system to increase or decrease a number store in a variable but...
debugger teel me:
[ERROR] 21:22:08: line 16: attempt to perform arithmetic on global 'ripetizione' (a nil value)
example code for this error:
then
fibaro:debug("luce gia accesa incremento vaiabile di 1" );
ripetizione=ripetizione + 1 <-------------------------------------this
ho can i manage (sum and difference) global variable?
16 answers to this question
one of many ways
    i don't know well lua, but there isn't possiiblity to make a classic loop with variable controller by another scene?
    i want to make a lua script like a (sorry for my english) crepuscolar system with auto incease timer...i hate walk on the stairs and light end countdown....
    scene 1.....
    under 100 lux and movement detected and variable start=0 (script not run and light non powered on)
    launch scene 2
    else if
    start=1 lux under 100 and movement detected then
    ripetizione=ripetizione+1 (switch yet powered on)
    scene 2:
    repeat
    set start =1
    switch on light
    wait 60 sec
    ripetizione=ripetizione-1
    until ripetizione < 0
    set start = 0
    set ripetizione = 1
    switch off light
    sorry for my bad english.....
    I think the only way on HC2 would be to use a variable defined in the variable panel. These are strings but you can always cast tonumber.
    The LUA scenes on HC2 are sandboxed and do not give you access to many features including those you would need to do this in a cleaner way.
    I think you can do what you want in one scene though. Just check what triggered the scene to run and increase or decrease the counter.
    only in 1 scene?
    mmm...it's possible?
    yep
    check the instance count
    if first instance update variable and start loop with sleep and decrements variable each minute
    if second instance add to variable and kill the instance without loop
    [/code]
    ok but for increase and decrease variable i must use function .... no?
    no you just need to initialize the variable to a value. As you will get the value from the function call to get a variable value
    You will be running a couple of threads of code so you may get odd behavior in some rare instances but that would be true with two scenes also.
    you can do that in a less verbose way in LUA but that is easier to read
    debugger tell me ...
    [ERROR] 11:18:21: line 25: attempt to perform arithmetic on local 'ripetizionetemp' (a nil value)
    scene programming fibaro is not Like LUA it's a surrogate....
    you must have a variable ripetizione in the variable panel or you will be trying to do arithmetic on nil and get that error
    go to panels variable panel on HC2
    Hit add
    type ripetizione for the name and the code will work
    A neater way to write the lines is
    or
    and yes it is a sandbox so access to a lot of important features is blocked.
    I don't understand the logic of the restriction as the box should never be exposed to internet so you could only break it for yourself.
    I would love wider access as there is a lot that could be done but the environment and setmetatable etc are all blocked so you do not have access to the LUA environment tables.
    You can therefore not add your own code libraries or LUA globals as you were trying.
    Going back to your original post... you get this error because you are trying to do arithmetic on a nil value as you are with the code I posted if you do not define a variable in the HC2 panel.
    If you need to do this type of thing consider using an "or" in the assignment statement to ensure that the variable is initialized to a value if it is the first time through the code.
    a question:
    i've complete code and i use a repeat until cycle but lua but debugger not like end of cycle….it tell me:
    [ERROR] 15:24:35: line 47: attempt to compare number with nil
    but "ripetizione" is not nil i've set a tea number….
    the code…
    local var3
    local var4
    local total1
    local contatore
    if (
    ( tonumber(fibaro:getGlobalValue("Termperatura ")) == tonumber("10") )
    or
    then
    fineciclo = 0
    repeat
    fibaro:debug("Inizio Ciclo")
    fibaro:setGlobal("IrDentro", "1")
    fibaro:call(124, "turnOn");
    fibaro:sleep(10*1000)
    var3=1
    fibaro:debug("variabile var3 settata a 1")
    fibaro:debug(var3)
    var4=fibaro:getGlobal("Ripetizione")
    fibaro:debug("variabile var 4 che è ripetizione prima del decremento")
    fibaro:debug(var4)
    total1= var4-var3
    fibaro:debug("sottraggo,la variabile totale è")
    fibaro:debug(total1)
    --scrivo il dato nell variaible
    fibaro:setGlobal("Ripetizione", total1)
    fibaro:debug("copio ripetizione in variabile contatore che passo al fineciclo")
    -- fibaro:debug(contatore)
    until Ripetizione > 0 >----
    fibaro:setGlobal("IrDentro", "0")
    fibaro:setGlobal("Ripetizione", "1")
    fibaro:call(124, "turnOff");
    fibaro:debug("Spengo la Luce")
    I have not checked the logic you have used as we all have different styles but your error comes from this line.
    Ripetizione is not the variable in fibaro panel and is not initialized so is nil
    assuming all else is correct... try
    doesn't work...
    [ERROR] 17:13:54: line 48: bad argument #2 to 'tonumber' (base out of range)
    OK need a break from what I am doing.
    You have an IR sensor and you want it to turn on and keep the light on while movement is detected?
    have you got the IR sensor triggering the scene?
    [ Added: 2013-08-25, 18:17 ]
    yes, sure my rule for switch on light is:
    -IR sensor violated and not armed id: 116
    -Lux sensor < 500 lux id:119
    sorry but i'm newbie of LUA....
    for start scene what do you means?
    have edited the code but I don't have any light sensors or IR in my system just now so not sure I have used correct property.
    if it does not work post what you get back when you put the following lines in your browser address bar
    /api/devices?id=116
    /api/devices?id=119
    Hi Fibaro,
    It would be good if global variables were valid across instances of scene so we could write this like...but just now all variables are local to an instance of a scene
    /emoticons/default_icon_confused.gif" alt=":-?" />
    the script works perfectly......rob pm...
