Is there a possibility to set the startup level of the fgd221 dimmer?
I like to change the startup level depending on the time of the day.
Example.
Kids room
21:00h set to 30%
07:00h set to 100%
TANE, yes from 1.9 version parameter 40
example
you got it on 99%
you set up parameter to 25
nothing change, when you press turn off and again turn on (from button) it will set up for 25%, but if you press from hc2 interface turn on will go to 100%
I have dimers with version 2.2 but cant find parameter 40?
Do i need to do anything?
[ Added: 2013-09-18, 19:17 ]
No one??
I have made a solution for this by creating a variable called night and have a scene that set i to 1 at 22:00 and to 0 at 06:00. I have also made a variable called softstart that is 0. It sets to zero at 22:00 and by it self after 5 sec when lamp is off.
Then I have made a scene that tigger on when lamp is >0 and also check if night is 1 and softstart is 0 then it set the dimmerlevel to 1 and softstart to 1.
The use of softstart makes it possible to adjust the dimmerlevel to whatever you want after you have lit it even if night. when I turn lamp of it takes five sec until softsart sets to 0 and all is ready for next use.
Hope this can be a Little help
Andreas
It would be great to set startup dim level for alla dimmer and maybe use your programing on some light.
But as mentioned there should be a parameter 40 wich i cant find.
39 then 41 so no 40 in the middle
Guest Kuuno
disable the use templates for parameters and add manually parameter 40
Ah of course thats the simple solution.
Is it going to be placed in template later?
