2 cars , 2 fibaro door sensors
Guest imparator
Hi, all
I want to put 1 fibaro door sensor in one Car ,
We have 2 cars
I want to create a script that checks if the cars are at home or not
And if they come or go , so i can get a push Message to my Phone
Car come's at home send push to phone "Car 1 is at home"
Car is gone send push to phone "Car 1 is gone"
The same for car 2
Is this possible ?
9 answers to this question
Don't think this will work well..also the rang of the door sensor can be a problem.
Better to use the GPS or IP
When you can ping the phone you can say user is at home.
You can use the users phone...or use a old phone and leave this one in the car with wifi enabled and just check the status of the phone.
or if your really good at parking attached the magnet to the car and leave the sensor within parking distance
/emoticons/default_icon_wink.gif" alt=";-)" /> a few mm!
p.s probably not wise to try this with the wife driving!
you can use pilot locator from Fibaro. You will know that car is in house;)
Guest imparator
    Hi
    I don't know this one!?
    Where can you buy it and how it works ?
    It works with expander. Every 30s pilot give impulse and expander know that pilot is in the range.
    You can buy it from me (Poland).
    these run on 433mhz yes?
    Yes
    Do you have any screenshot how they look in hc2?
    How do You want to add them into HC2 if they are 433Mhz? You connect this remote control with Expander and expander is connected with for example relay switch. When You give command on remote control it sends info to expander and expander give info to relay (pressing button on remote control can open garage and using scene You can switch off/on other devices)
    If You ask about location controler than I cannot help becouse I have never used it before.
