Control of Hue lights using virtual devices
Looking at the Hue API, it seems to me that one should be able to control Hue lights using a virtual device and some LUA code to post over http.
I'm going to play around and try to get this working (based on some of the Sonos examples) - in the meantime I'm sure there are other more development minded people on this board who might be able to get a quicker result - so I have posted the link to the API test examples.
I'll update if I get anywhere...
automationfan, you got ready script on forum created by user
    I got the impression that this script required a third party web sever which I don't have?
    I wanted to control the lights by talking directly to the bridge?
    Yes, you need web server. A rapsberry is enough.
    If anyone is interested, I can control the Hue lights without an intermediary web server, using two lines of LUA code in a virtual device.
    I'm interested
    The best way, is fibaro give choice for the slider to set value. (1 to 99 or some color)
    OK - a few people have shown an interest in this.
    This is a simple way to control Hue bulbs directly using virtual devices, without needing a web server or any other software.
    1. Register a new user on the bridge API
    You press the button on the hue bridge and then use the clip debugger to POST to the bridge.
    Instructions are on this page:
    I created a user called 'automation1' for this (for some reason you can't use 'fibaro')
    2. Create a virtual device with the following LUA code (depending on what you want to do):
    -Change the IP below to that of your Hue Bridge.
    -Change the URL to include your username (I used 'automation1')
    -The number 8 in the URL is the reference to light 8 on the bridge - so change this depending on what light you want to control.
    Turn light on - warm white:
    HueGtw = Net.FHttp("192.168.1.11",80)
    HueGtw:PUT('/api/automation1/lights/8/state', '{"on":true, "sat":255, "bri":255,"ct":400}')
    Turn light off:
    HueGtw:PUT('/api/automation1/lights/8/state', '{"on":false}')
    Change colour:
    HueGtw:PUT('/api/automation1/lights/8/state', '{"on":true, "sat":255, "bri":255,"hue":60000}')
    All the various parameters are documented here:
    I'm sure there are cleverer ways to do this, but for me this provides a simple and effective control via virtual devices, and can be included in scenes etc for effective integration of Hue lighting with the HC2.
    Hope this is useful for someone.
    Paul
    Thanks, i'll try this!
    [ Added: 2013-09-09, 20:46 ]
    It works
    /emoticons/default_laugh.png" alt=":lol:" />
    If you can do this with an sq blaster, would be fabulous!!!!
    Great work
    it works great...thankyou...
    con can i get value of slider variable???
    Glad it was useful
    The next thing I would like to do is create a scene can tell when a Hue bulb changes state to trigger other devices - this was I can use the Hue Geofencing whichworks rather well (Fibaro seems to randomly switch my lights on when I'm already at home..>)
    [ Added: 2013-09-14, 11:58 ]
    Got the slider working to adjust the colour in the virtual device:
    Works really well!
    and...finally if can i help this is code lua slider (i add 2 slider) for intensity of hue..
    HueGtw = Net.FHttp("192.168.1.254",80)
    vHue = _sliderValue_ * 2.55
    HueGtw:PUT('/api/automation1/lights/3/state', '{"on":true,"bri":'..vHue..'}')
    now with a virtual button on off and 2 slider it can possible full control of bulbs...
    Excellent! I have been looking for a way to make Hue and Fibaro work together. This seems like a good solution. Keep up the great tips and tricks :->
    Guest shapa
    Some add ons:
    Alarm mode (pulsing) for 30sec:
    HueGtw = Net.FHttp("172.16.1.62",80)
    HueGtw:PUT('/api/automation1/lights/4/state', '{"on":true, "alert":"lselect"}')
    Alarm mode (one pulse)
    HueGtw:PUT('/api/automation1/lights/4/state', '{"on":true, "alert":"select"}')
    Colorloop
    HueGtw:PUT('/api/automation1/lights/4/state', '{"on":true, "effect":"colorloop"}')
    ColorLoopOff:
    HueGtw:PUT('/api/automation1/lights/4/state', '{"on":true, "effect":"none"}')
    Guest cedriclocqueneu
    Great ! Thank you for this tips, it's really better without need of an external server !
    And it's really fast
    Thanks a lot
    I cannot make this code for controlling the brightness work:
    Has anyone had succes with this?
    I now have an on and off button as well as a slider to control the color thank to some of the other code posted to this thread
    Did you register automation1 as devellopper in your hue gateway
    Yes, all the other Lua code you guys have been posting works flawlessly - just not the above mentioned "dimmer" slider
    Until i can get the slider working, I've made a five button dimmer with 20% increase of brightness between each button. It's not as sleek though
    The Slider for Controlling the Brightness is working for me .
    I have solved my brightness slide "issue".
    I do not know if it is a problem with my HC2 in particular (maybe european standard symbols or something), but I had to change a . (punctuation mark) into a , (comma) in the code:
    Mine is now:
    vHue = _sliderValue_ * 2,55
    Just a heads up if anyone else encounters this problem
