FGS221 Switch 2x1,5kW : disable S1 and/or S2 input
candrea77
Hello to all,
i've got an FGS221 connected to an external PIR sensor in order to turn on some garden light when the PIR detect a movement.
PIR is not zwave.
FGS is setted as bistable switch (toggle switch) and manual ovverride is disabled. Auto poweroff is set to 60s.
PIR output ON --> Light ON
PIR output OFF -> Light OFF
I would like to have the ability to :
* - Set the light always ON (in case i would like to have light on even the PIR don't detect movement)
* - Set the light always OFF (in case of high speed wind that generate false positive on PIR)
For light always ON i can create a lua script that turn on device every 58s
I have problem to understand the way to override any switch control and set the light always OFF !!!!!
Thank you in adavnce for any idea !!!!!!
Bye
