Quikdav 15
Hi all
I would like to use my EZMotion to switch off a light if there is nobody into the room since 10 minutes. So I configure the parameter 2 to 10 minutes. My concern now is to know which properties from the EZMotion (in section %% properties) I could use to trigger a scene when I receive the Z-Wave OFF command. I tried 'value', 'wakeontime' but it doesn't work. I don't see which other I could use !!!
Here is the documentation for this parameter :
Motion Timeout
The On-Time parameter is the time from the when the last motion was detected until it sends a Z-Wave OFF command. On-Time is programmable from 1 minute to 25 hours and the default is 20 minutes. ZWave Configuration Class commands are used to program the On-Time setting. See the home-control application documentation for the procedure for adjusting the Motion Timeout.
Setting On-Time to zero will cause EZMotion+ to not send a Z-Wave OFF command but instead it will send an ON command each time
Thanks a lot
Regards
David
