Quikdav 15
Hi all
I have 3 different virtual devices that use JSON to request ethernet cards. These devices set some global variables that are used by other virtual devices for display purpose only because from one card, I can get many data (energy comsumption, temperature, etc)
Here is the code of the main loop for one of them:
HC2 = Net.FHttp("192.168.11.20")
response ,status, errorCode = HC2:GET("/api/xdevices.json?cmd=10")
fibaro:log("Status = " .. status)
if (tonumber(status) == 200) then
response = json.decode(response)
fibaro:setGlobal("ABO", response.T1_PTEC)
fibaro:setGlobal("CONSO", response.T1_PAPP)
else
fibaro:log("ErrorCode = " .. errorCode)
Whenever I disconnect from the HC2 web interface, they seem to pause or to failed requesting my cards. That means each time I connect to the HC2 web interface, the display of the devices is not update. So I have to run main loop with debug button and the script restart agains and is working !!!
Sometime, nothing is display with the fibaro:log or I have errorcode = 2
I wonder if running the script each second is not too fast !! I don't know if I can insert a sleep command in so far the script is running each second !!! I'm afraid it will stack all the call to the script !!!
Any idea regarding this issue ?
David
[ Added: 2013-09-13, 10:44 ]
On the advice of Socha, I had a sleep command at the end of my script. It seems to be better but after some time, I have errorcode=2. Once in this mode, my script seems to be unable to return to a normal operating mode with status = 200
What does this code means ?
David
