JanJoh 1
Right.. I have an AEON 4in1 on my front porch.
I wanted to create a scene that sets a variable to High / Low / Medium depending on the value of the Light meter, in order to (i thought) be able to turn on my walk way lights when it is dusk (medium light)
I created a variable "LightLevel" with three values "Bright" "Dim" "Dark"
Butm, when I go into blocks, I cannot do any such thing it seem?
I thought i should be able to select the sensor (that I can do). Select < (that I can do) then enter 200 (which i can NOT do)
then i thought i could add a THEN and after that set a "set variable "light level" to "Dim" (That I can do):
So, how to I access the value of the light sensor from my scene?
(Running 3.560
