Hello!
Ocasionally i get "Dead node" on my Wall Plugs. But, they always work fine as soon as i "wake dead node". This happens regardless of where in my house i have the WP in relation to the HC2 (Running 3.560).
What settings (if any) can help me to make the system more tolerant for whatever may be causing this?
Is your problem resolved? I have the same problems since yesterday...
    Yep. Solved. I installed a dimmer module in the same room to have an additional routing node. Rock stable ever since.
    So, i guess it was an interferance issue.
