Ucciogenerale 2
After the implementation of the usefull scheduler provided from Robmac, I defined an alarm panel (see the attachment) in order to update the timing set in a global variable instead of changing it always through the code.
First of all you have to define a multiple global variable type HH:MM
Then you can define a virtual device with labels and buttons.
In the main loop of the virtual device you can set the code to show in the label.
e.g. in my case
---------------MAIN LOOP CODE-----------
local newora = fibaro:getGlobalValue("Sveglia")
H = string.sub(newora, 1, 2)
M = string.sub(newora, 4, 5)
if tonumber(H) < 23
then
H = tonumber(H) + 1
else H = 0
if string.len(H) < 2
then H = string.format("%s%s", '0', H)
else
newora = string.format("%s:%s", H, M)
fibaro:setGlobal("Sveglia", newora);
---------------END MAIN LOOP CODE-----------
and the buttons to change the hours and minutes (HH:MM)
e.g. in my case the wakeup time to start a scene using the Robmac scheduler
----------BUTTON 1 H[+]--------------------------------------
if tonumber(H) < 23
then
H = tonumber(H) + 1
else H = 0
else
----------END BUTTON 1 H[+]--------------------------------------
Consequently the other buttons are simple to retrieve.
------------------[H-]---------------------------
if tonumber(H) > 0
then
H = tonumber(H) - 1
else H = 23
else
------------------[H-] END---------------------------
------------------[M+]---------------------------
if tonumber(M) < 50
then
M = tonumber(M) + 10
else M = 0
if string.len(M) < 2
then M = string.format("%s%s", '0', M)
else
------------------[M+] END---------------------------
------------------[M-]---------------------------
if tonumber(M) > 0
then
M = tonumber(M) - 10
else M = 50
else
------------------[M-] END---------------------------
Then to submit to the Robmac scheduler immediately the defined time (you can force but if I well understood the scheduler refreshes every 12 hours automatically) the last button "UPDATE".
------------Button UPDATE------------
fibaro:killScenes()
fibaro:startScene()
------------END Button UPDATE------------
Regards
Marco
PS: Due to a technical Fibaro's website problem I am not currently able to upload the picture sample above mentioned.
I will post it later as soon as the "Technical maintenance warning will disappear".
[ Added: 2013-09-09, 22:08 ]
here is the image
4 answers to this question
