[Virtual Device] How put a stringvariable as buttontext
First of all, hi to your all!!
I just taking the first steps of knowing the Fibaro HC 2 system, and so far I like it!
And please, be patient with me, I have this strange returning habit to ask dumb questions....please don't shoot.
Also I'm making my first baby steps in LUA and programming.
the question I have:
I created a virtual device which has one button.
What function do I need to change the text by a string-variable?
[ Added: 2013-09-09, 22:04 ]
Nevermind. It's not (yet) supported....
8 answers to this question
Hi Lambik,
if I well understood the question you are trying to change the label of a button through the code. At this stage this function is still not available but, you can define a label near to the button and you can change it through lua code.
See the file here attached and if you want take a look at the post I made just few hours ago.
Regards
Marco
    I'll take a look at your post. I'm very new to this kind of programming, so I will learn from your script.
    Thanx for your respond. It's highly appreciated!!
    I think the JSON API would let you do this. A bit heavy weight though.
    Do you have an example how to do this?
    With comments if possible. Like I said, I'm new to programming...
    but give it a good test and back up before testing
    Wow!
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    I've got a lot to learn!
    I do some testing in the (near) future.
    Thanx!
    robmac, but the caption for the button is refreshed only after the page is reloaded
    /emoticons/default_icon_wink.gif" alt=";-)" /> it's not friendly to do a toggle button
    As I said earlier in the thread it is not a great solution. It is a very heavy weight way to change a single button caption and I am not even saying it is safe. Thus the warning about testing.
