[Virtual Device] Toggleswitch, change status global variable
This is my first programming effort to create a Virtual Switch to toggle a global variable which I use to 'arm' my IP-camera on my balcony.
It works but maybe you got comments. Please do!
Global Variable:
BalkonBew_AU - with value '0' and '1'
Main Loop
1 button Label: Aan/Uit (means On/Off) ID: button_0_0
Label1 Label: Balkonbewaking (means Balconysecurity) ID: Label1
9 answers to this question
in Main Loop use fibaro:sleep, for better performance
    Can you give me full command and place to insert, please?
    that will give you 10s pause
    but you can do that code in other way
    Put fibaro:sleep(60000) at the end of your main loop script ;/), loop refresh every minutes with 60000
    [ Added: 2013-09-09, 23:05 ]
    Sorry A.Socha
    Thanx guys!
    Updated my first posting.
    Hi all,
    Just for clarification, that means calls to main loop are not stacked !!!
    I understood that main loop was called each second some there is no problem to call the sleep command into a procedure that is called each second ?
    David
    yes, next loop will start when last loop will end, so it will not be every 1s, but every time what you will use in sleep
    Thanks...This is an important information
    I have 2 virtual devices that request ethernet cards but it take some seconds before receiving the result. These devices seem to be on standby sometime so I thought it was because of the call each second to the main loop
    I need help please.
    I tried to modify the VD from Lambik and make a simple VD to see the status of the kitchen TV depending on a global variable:
    Value 1: TV ON
    Value 0: TV OFF
    The status should be updated only if the global variable changes and not check the variable each e.g. 10 sec.
    ...but without success
    My problems are:
    1) the lable don't change
    2) the status will be chacked each 10 sec.
    3) the status text appears only for a short time
