Virtual devices: possible improvements !
This is an open list
- The ability to change the label of a button on the fly with lua.
- The ability to use a icon in a button and update it on the fly with lua.
- The ability to enable/disable button on the fly with lua.
- The ability to have multiple pages or tab.
- Add a listbox component, useful for the selection of a numerical value (temperature), choice several state ...The slider is not optimized in many situations.
- Add a picture component (visible on the main page).
- More flexibility for the slider: minimum value, maximum value, step value, custom label.
- Share lua code and make it reusable (ticket on bugzilla ->
- open more lua code for better integration, please
Best regards.
7 answers to this question
Text input
video
background image
event driven main loop not running every 1s but controlled like scenes
import / export
find and replace on advanced tab
Do you now if it is possible to change label of virtual device???
Shad: What do you want to do exactly ?
Else as improvement, the ability to configure the font displayed in label (mainly the size) and the width of device with label only
Change via api the label of virtual device.
Shad, what you mean by api?
now working by LUA
fibaro:call(, "setProperty", "ui.Label1.value", "text");
or by PUT
thanks andrew.
Want to use that with url api.
But that it is ok.
Hi Andrew,
I know the following inserts new code into the system but is it a safe thing to do? Is it tested?
fibaro:call(, "setProperty", "mainLoop", "some lua code");
or by PUT
I have a use case that could work by changing the main loop depending on last button pressed but I am always a bit dubious of dynamic code. Particularly as the code could be running when the change would be made.
